Hi All,
I'm new to using the KFlop controller. Currently, I'm making a program in VB (Visual studio 2013) to control an advanced 3D printer using KFlop configured as pulse / direction output.
I've got everything up and running and it's working pretty well, even with all 8 axes. It seems to be sending out all the right pulses. However, I've got this problem that during movement, the KFlop controller returns position values that are 1E+10 or 1E+11 too high when I request the position using the "Dest<n>"-command. The Pos<n>-command does not seem to work, it always returns 0.
If I just use the standard move<n>= command, I see that after the movement is finished, the size of the number returns to the normal value. However, if I use the jog<n>= command, the value returned by the Dest<n>-command remains a factor 1000000000 too high after the jog value has returned to 0.
When I open the KMotion-app at the same time with my app, I see that the Axis screen of the KMotion app shows the right values, So, for example: my app shows: -5697756279069,00 whereas KMotion shows -569.78.
At first I thought I made some programming error, however, the VB example named Dynomotion VB.net on the Dynomotion website has exactly the same problem. If you compile it and use the jog, it will show a very high value for the position, whereas the KMotion-app will at the same time display a value ten billion times lower. I tried Visual studio 2008, but the same problem here. Also it is not a question of the right use of the formatNumber command.
Anyone have an idea how to solve this issue? It seems to be an error in the supplied dlls.
Best regards, Jeroen
